  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
ABAQUS VUMAT Error
Abdelrahman993
11
0
0
CA
I'm new to using ABAQUS VUMAT subroutine and I'm trying to run the constitutive model provided in ABAQUS manual. The analysis is complete but I got this error and there are no results
***ERROR: Floating Point Exception detected in increment 1 on Domain 1 after
Output Requests. Job exiting.
Does anyone know how to solve this problem?
Let's focus on the first part of the error. This message is quite generic but the following tests may help:
- running the job without subroutine
- running a very simple model (like a single element test) with this subroutine
- trying other subroutines from documentation (maybe this problem is caused by the link between Abaqus and compiler on your machine)
Apart from that, make sure that there are no other errors in the output files.
I'm already running very simple model (one beam element) to test the subroutine and there is no problem in running it without subroutine
And there are no more errors in the output files, it says THE ANALYSIS HAS COMPLETED SUCCESSFULLY while there are no results.
Thanks for your help
