ABAQUS
mehrangol
3
I have a problem applying displacement boundary conditions in two differents planes with a common edge.
The displacement normal to the planes have to be set two zero. I have created a local coordinate system. However, this causes a problem.
When I create the input file, I obtain the following message.
"The following pairs of attributes are applied to overlapping/intersecting/adjoining regions in differing coordinate systems."
How is it possible to sort out this issue? (without equations)
