Apr 10, 2020 #1 nermine Mechanical Jul 19, 2019 2 Link Link Link Hey Guys ! I ran my job and I found this ! Do you guys have any idea ? I have a model with one deformable part and two rigid bodies, It's a thermo mechanical problem so my step is Dynamic,temp-disp explicit. I can send you my inp file if you want by email
Apr 10, 2020 #2 FEA way Mechanical Nov 13, 2018 5,015 As suggested in the error message, you should either assign temperature to the reference point of isothermal rigid body or specify point capacitance (Special —> Inertia —> Create: Heat capacitance). Upvote 0 Downvote
