The inspector stated that there is a Category D joint where the shell connects to the nozzle. However, since the shell is flat, the nozzle is not at 90° but at 45°, which, according to UW-3, classifies it as a Category B joint instead.
As a result, for NDE inspection, PAUT should be performed as required for a Category B joint, rather than UT, which applies to a Category D joint.
I need to verify whether this interpretation is correct.
Could you provide assistance with this matter?
