About copy - paste special - copy with link in product 1
yamaCad
Turkey
Hello all,
I'm trying to create a macro which is copies body and paste special with link in a Part (part_b). Then we going to paste special with link into other Part (part_a).
Firstly the body is published.
lets call it body_a
Maybe you know. In product when you trying to record a macro It give like this. It's broken like this:
Code:
Language="VBSCRIPT"
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set selection1 = productDocument1.Selection
selection1.Clear
Set documents1 = CATIA.Documents
Set partDocument1 = documents1.Item("part_b.CATPart")
Set part1 = partDocument1.Part
Set bodies1 = part1.Bodies
Set body1 = bodies1.Item("body_a")
selection1.Add body1
selection1.Copy
Set product1 = productDocument1.Product
Set products1 = product1.Products
Set product2 = products1.Item("part_b")
Set partDocument2 = documents1.Item("part_a.CATPart")
Set part2 = partDocument2.Part
part2.Update
End Sub
I created a simple one but didn't figure it out how to work in product.
Here is my code:
Code:
Sub CATMain()
    ' CATIA oturumunu al
    Dim CATIA
    Set CATIA = GetObject(, "CATIA.Application")
    ' Aktif dokümanı al
    Dim activeDoc
    Set activeDoc = CATIA.ActiveDocument
    ' Seçim nesnesi oluştur
    Dim objSel
    Set objSel = activeDoc.Selection
    objSel.Clear
    ' "part_b" adlı Product'ı ara
    objSel.Search "Name=part_b,all"
    ' Eğer part_b bulunduysa devam et
    If objSel.Count > 0 Then
        ' part_b'yi al
        Dim PartB_Product
        Set PartB_Product = objSel.Item(1).Value
        ' "body_a"yı part_b içindeki body'leriyle bul
        Dim PartB_Bodies
        Set PartB_Bodies = PartB_Product.ReferenceProduct.Parent.Part.Bodies
        On Error Resume Next
        Dim body_a
        Set body_a = PartB_Bodies.Item("body_a")
        On Error GoTo 0
        ' Eğer body_a bulunursa, kopyalama işlemi yap
        If Not body_a Is Nothing Then
            MsgBox "body_a bulundu, kopyalanabilir"
        Else
            MsgBox "body_a bulunamadı"
            Exit Sub
        End If
    Else
        MsgBox "The product 'part_b' was not found."
        Exit Sub
    End If
    ' part_a adlı Product'ı ara
    objSel.Clear
    objSel.Search "Name=part_a,all"
    ' Eğer part_a bulunduysa devam et
        ' part_a'ya geçiş yap
        Dim PartA_Product
        Set PartA_Product = objSel.Item(1).Value
        ' part_a dokümanını al
        Dim PartA_Doc
        Set PartA_Doc = PartA_Product.ReferenceProduct.Parent
        ' part_a Part'ını al
        Dim PartA_Part
        Set PartA_Part = PartA_Doc.Part
        ' Seçim nesnesini oluştur
        Dim selection2
        Set selection2 = PartA_Doc.Selection
        selection2.Clear
        ' Yapıştırma işlemi
        PartA_Doc.Activate
        PartA_Part.InWorkObject = PartA_Part.MainBody
        ' PasteSpecial komutunu kullanarak kopyayı yapıştırma
        selection2.PasteSpecial "CATPrtResultWithLink"
        ' Güncelleme işlemi
        PartA_Part.Update
        MsgBox "body_a başarıyla part_a'ya aktarıldı!"
    Else
        MsgBox "The product 'part_a' was not found."
        Exit Sub
    End If
End Sub
You should use the Section object of root ProductDocument, don't use Selection of PartDocument.
The parameter for "AsResultWithLink" is "CATPrtResult", not "CATPrtResultWithLink" , you can find this from Automation Help.
Here is my code, you can take a look
Code:
Public Sub CATMain()
    Dim part_a As Part, part_b As Part
    Dim body_a As Body
    Dim rootPrdDoc As ProductDocument
    Set rootPrdDoc = CATIA.ActiveDocument
    Dim sel As Selection
    Set sel = rootPrdDoc.Selection
    Dim rootPrd As Product
    Set rootPrd = rootPrdDoc.Product
    Set part_a = rootPrd.Products.Item(1).ReferenceProduct.Parent.Part
    Set part_b = rootPrd.Products.Item(2).ReferenceProduct.Parent.Part
    Set body_a = part_b.Bodies.Item("body_a")
    'If the Part is activated, the copy and paste will fail.
    Dim designEnv As String
    designEnv = CATIA.GetWorkbenchId
    If designEnv <> "Assembly" Then
        CATIA.StartWorkbench "Assembly"
    End If
    sel.Clear
    sel.Add body_a
    sel.Copy
    sel.Add part_a
    sel.PasteSpecial "CATPrtResult"
    part_a.Update
End Sub
Code:
    Dim body_a As Body
    End If
    sel.Clear
    sel.Add body_a
    sel.Copy
    sel.Add part_a
    part_a.Update
End Sub
Thanks. I found the automation documentation. Thank you so much It looks cool :) I got notes from my mistake btw here is my version.
Code:
Sub CATMain()
    ' CATIA Uygulamasını Al
    Dim CATIAApp
    Set CATIAApp = CATIA
    ' Aktif Belgeyi Kontrol Et
    If CATIAApp.Documents.Count = 0 Then
        MsgBox "Bir ürün veya parça açık değil. Lütfen bir ürün veya parça açın."
        Exit Sub
    End If
    ' Aktif Belgeyi Al
    Dim activeDoc
    Set activeDoc = CATIAApp.ActiveDocument
    ' body_a'yı Kopyalamak için Seçim Nesnesi
    Dim objSelBody
    Set objSelBody = activeDoc.Selection
    objSelBody.Clear
    objSelBody.Search "Name=body_a,all"
    If objSelBody.Count > 0 Then
        objSelBody.Copy
        MsgBox "body_a başarıyla kopyalandı!"
    Else
        MsgBox "body_a bulunamadı!"
        Exit Sub
    End If
    ' part_a'yı Bulmak için Seçim Nesnesini Temizle ve Yeniden Kullan
    objSelBody.Clear
    objSelBody.Search "Name=part_a,all"
        ' Yeni Pencerede Aç
        CATIA.StartCommand "Open in New Window"
        MsgBox "part_a yeni bir pencerede açıldı!"
    Else
        MsgBox "part_a bulunamadı!"
        Exit Sub
    End If
    ' Yeni Açılan Pencereyi Al
    Dim newDoc
    Set newDoc = CATIAApp.ActiveDocument
    On Error GoTo 0
    If newDoc Is Nothing Then
        MsgBox "Yeni pencere açılırken bir hata oluştu."
        Exit Sub
    End If
    ' Yapıştırma Öncesi Doğru Hedefi Ayarla
    Dim targetProduct
    Set targetProduct = newDoc.Product
    ' Hedef Body'yi Seç
    Dim objSelTarget
    Set objSelTarget = newDoc.Selection
    objSelTarget.Clear
    ' Hedef: "PartBody" veya Başka Bir Body
    objSelTarget.Search "Name=PartBody,all"
    If objSelTarget.Count > 0 Then
        objSelTarget.Add objSelTarget.Item(1).Value
        objSelTarget.Paste
        MsgBox "body_a başarıyla PartBody içerisine yapıştırıldı!"
    Else
        MsgBox "PartBody bulunamadı. Lütfen part_a içerisinde geçerli bir hedef olduğundan emin olun."
        Exit Sub
    End If
    ' Seçimleri Temizle
    objSelBody.Clear
    objSelTarget.Clear
End Sub
Code:
    Dim body_a As Body
    End If
    sel.Clear
    sel.Add body_a
    sel.Copy
    sel.Add part_a
    part_a.Update
End Sub
Also I wanted something like this is this possible? I take body name information I have 5 parts with same name with same bodies. I want copy all of this bodies from selected parts. And copy into main part. I set up something like this I selecting the bodies in one part after that in next textbox I select the parts at third part I select the paste part location. I planned a cycle. But about code didn't figure it out. I will share tonight at least how can I manage this bodies
