Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Eh?
What calculation?
The last part of that sentence makes no sense at all.
What "issue"?
No doubt you know what your point is, but I'm afraid I don't from the minimal amount ofmjnformation supplied.
I read this post three times and still i am not sure that i got your point.is there a rule specified in API650 to calculate the weight per foot in IFR and compare the calculated weight with the strength of the foot in IFR?
I guess you are asking the design loads for the legs . If so, you can calculate the support reactions using tributary areas or better adopt FEM .I would like to ask, is there a rule specified in API650 to calculate the weight per foot in IFR and compare the calculated weight with the strength of the foot in IFR?
