ABOUT MULTI SECTIONAL HEADS
yigithan
7
Hı everyone
I have a question for all of you :)
For a pressure vessel wihich is manufactured and designed acc. to EN13445 and diameter is 3.2mt. Is that any rule for torispherical end for manucaftured multi section ? For exaple can manufactuerer fabricate the head with 15 pieces of sheet ?
A person would have to read EN13445 to know for sure (I have no copy of same), but I'd be surprised if multi-piece heads were not allowed.
Mike
You can fabricate with two or more parts, but 15 parts is excessive in this case.
EN 13445-4 Fabrication
9.2.5 Forming of Segments
The following equation (9.2-5) shall be used for the calculation of deformation F of segments e.g. of multi-sectional
torispherical heads or spheres (see also Figure 9.2-5.
r6155
