KingHVAC
Industrial
- May 9, 2013
- 6
I have a package unit where the AC is being called for, but the compressor contactor wasn't pulling in. There was no voltage to pull in the contactor (24 v), but the thermostat was calling for it. I had voltage at the contactor and went to bump it to see if the compressor would run. When I pushed it in, it stayed pulled in and ran, and suddenly I had voltage (24v) to pull in the contactor!
Now I assume there must be an issue with one of the switches that the 24v goes through before it gets to the contactor to pull it in, but, I'm curious as to how the contactor stays pulled in and the 24v shows up upon pushing the contactor in? When I turned the power off and back on, the original situation returned. When I bumped the contactor again, it stayed running and had the 24v again.
I just want understand how the contactor stays pulled in and the 24v shows up?
