Hi All,
New in the forum.
Apologies in advance for my lack of knowledge in matter, some things will be easy to understand for me, others, not.
I would like to learn and understand about motors, especially because work-related.
I have a small motor. The label says (and feel free to correct me):
- 24 V
- 1.2 A
- 2 W Max
- 0 to 60 Hz
- The motor has no permanent magnets but electromagnets as stator.
Other values are not relevant to me.
My questions are:
1. Why I cannot make sense of the 2 W? What I mean is: 24 V x 1.2 A should give me 28.8 W. Why the label states 2 W?
2. Why the labels states 1.2 A? When I run the motor at 24 V DC, I can barely measure 0.55 A.
3. When I measure the motor internal resistance, I read 12 Ohms on my multimeter. But when I run the motor at 24 V DC, I measure about 0.55 A. If I apply Ohm's Law, the resistance should be 24 / 0.55 = 43.64 Ohms. But the measured value directly with multimeter gives me only 12 Ohms.
In all furnace, I feel like I'm failing to understand the equations
V = I x R
and
P = V x I (or P = V2 / R )
None of the formulas I apply seem to make sense.
What am I doing wrong?
Thank you guys,
Marco
New in the forum.
- 24 V
- 1.2 A
- 2 W Max
- 0 to 60 Hz
My questions are:
V = I x R
and
Thank you guys,
Marco
