AC Frequency
megbers
7
How would one increase the frequency of an AC signal? I am looking into inductive heat treating and to my surprise the units are 10k dollars and up. I am trying to go from 110v, 60 hz to 110v, ~10kHz. Any ideas? Thanks
Possibly, an audio amplifier driven from a function (sine wave) generator. Higher power is available in guitar amplifiers.
I would think RF would be a problem if you did that. Heat trace cable has no need to be shielded at this point, so I doubt it is available.
I built something like this for my university thesis, except mine was a current-source inverter fed on a diet of 415V 3 phase at 20kW and an ample supply of cooling water.
How much power are you trying to transfer into the load? Audio amps for the semi-pro market are readily available up to about 1kW into a small load. A coupling transformer might be needed to impedance match the load coil to the amplifier. They're fun to build, especially trying to get hold of small quantities of large section ferrites.
image.php
Sometimes I wake up Grumpy.
Other times I just let her sleep!
I've just watched the youtube clip. That is disturbingly similar to the thing I built, but a lot smaller. The highlight of my project was getting over 7000 people evacuated from the engineering buildings one snowy November day - my birthday funnily enough - after smoke started pouring out of a cable duct. There was a big inquiry about why the breakers had not tripped but I wasn't privy to any of that.
Very helpful info guys, thanks! Im looking to heat a ~1" dia steel rod to only about 400 deg on the surface. I dont think i need alot of power.
Ok, so the question is are you trying to achieve surface heating only or bulk heating? 10kHz suggests surface only in which case you need a powerful source to get energy into the surface layers faster than conduction can get it away from the surface into the core of the metal. Is this for a surface hardening application where you need a hard surface over a softer core? Also do you mean 400C or 400F? Big difference in power! I assume 400C for a metal hardening application.
BTW, have you considered adapting a bearing heater?
'Smoked,
My project was notorious enough before this incident: setting the university on fire elevated me to demigod status.
image.php
You are not alone Scotty!
There is a commissioning engineer at ABB. He is named Smokey after he burned down a paper mill in Israel. He is also quite famous.
Gunnar Englund
