ACAD General
SeanSweeney
NO
Is there a windows type programme which is helpful when extracting/viewing information from blocks in autocad. My company used to have a programme called PDOC which was a drawings interface which had all the fields listed in an explorer type way (that info from the title block). This was more than useful but compatability became a problem with 2005.
Any ideas? (I presume the solutions cost a good deal but any suggestions would be welcome). Thanks.
You could try searching this site..
I think I saw an extraction program there a while back. Otherwise a search on Yahoo or Google for Autocad lisp or autocad programs will turns up quite a few add-ons or special purpose software.
-Mike
If you want to extract the information from attributes try using the "attext" command. Try looking in the help file for info.
____________________
Acad2005, Terramodel
You are right attext works but only directly within the drawing. I was looking more for an interface programme which can read from the outside, like explorer does to a very limited extent, and not to title blocks in autocad.
Any other ideas - its a commercial interface programme I'm after.
If you are running Map I believe you can execute a query for attribute data. Also, if you will be doing this often I think you can set up an excel template to read the data. Check the help menu on attributes and excel.
