Hello coleagues
I am trying to assign F5 button as "define in work object" , when select a given object on the tree, but when I go tools -> customize -> commands the "accelerator" field is gray hence it does not allow me to assign the shortcut...
Can i change that somehow ? why some commands allow the "accelerator" field to be used (i already have assigned F2 as hide / show)?
thanks in advance and kind regards
