This problem is a subset of a more general problem I am facing. Is it possible to access information stored at integration points when using the *FRIC subroutine? If so, how is this achieved?
The motivation is to let the friction coefficient depend on the material properties which are stored in state variables, defined by the *USDFLD subroutine.
So far, I have tried directly accessing the STATEV array that is provided to *FRIC (this returns a value of 0.0. Could be because it is accessing the nodal SDV when the material data is at the IPs), using the utility subroutine GETVRM (also provided a value of 0.0) and I came across GETVRMAVGATNODE (this only works in the *UMESHMOTION subroutine). Is this something which commonly has to be worked around?
Any help is much appreciated!
