jreit
- May 2, 2014
- 95
Hello. I am checking a calculation where the concrete breakout strength is being calculated for an anchor group.
The image shows a sample plan view but the concrete section extends in the vertical direction.
The section is resisting a moment that is being resolved as a force couple with the concrete on the tension face being evaluated and hef = 32".
My issue is that the minimum concrete distance appears to be 3" which is much less than hef. As per ACI 17.4.2.3, if anchors are located as less than 1.5hef from three or more edges, then hef should be calculated as the smaller of max. edge distance/1.5 or max. spacing/3. This gives me a hef of 2" or 4" respectively.
However, using this value in Eq. 17.4.2.2a gives a Nb value of ~ 6.8 kips which is extremely small compared to the loading.
How should I treat this condition? Should my concrete breakout area be considered as the distance from the tension face rebar to the near edge (3") and far edge (19") and ignore the compression face rebar altogether?
