I am designing a pedestal over a spread footing to support a cantilevered hss column. The column has fairly large moments and very light axial loads. I believe the pedestal falls into the ACI 318-19; 2.3 definition of a beam, "Member subjected primarily to flexure and shear, with or without axial force or torsion...". Based on this, I plan to use the less stringent beam reinforcement requirements rather than the column requirements.
Does anyone know of a part of the code that actual defines a ratio of axial force to moment that allows you to design the member as a beam? I've looked through older posts on here but not had luck tracking down a definition like this.
Thanks.
Thanks.
