Hi, this is my first post.
Please guide me if I'm doing anything wrong, or similar question is already posted somewhere.
I'm designing special moment frame column detail.
According to ACI318-14, "18.7.5 Transverse reinforcement", column needs special detailing (closely spaced confinement) at plastic hinge zone (within L0). I'm bit confused and appreciate if someone can help me understanding the following questions.
1) Is this special detailing of confinement only required for columns where flexural yielding is likely to occur? or all column needs this detailing regardless of having flexural yielding or not?
2) Is satisfying the "Strong Column-Weak Beam" requirement as in 18.7.3 enough to prove that column will not have flexural yielding? hence special detailing is not required for these columns.
3) If question 2) is "NO", is non-linear-static-push-over-analysis be accepted to identify the hinge locations?
Thanks in advance.
Thanks in advance.
