AD2000 - B8 - Bolted Flange
u236
22
Dear All,
Is possible to design an elliptical flange with only two bolts?
like the connection flanges of the car mufflers, those with only two bolts?
Thanking all
You can design whatever you wish as long as it meets a given standard and/or code.
You have mentioned AD2000 B8 in your heading. As far as I understand, this flange standard only contains concentric flanges.
Do you require to meet a standard? and what do you want this elliptical flange for? Design parameters (size, material etc.) A drawing or a ?sketch would help.
Per ISO-4126, only the term Safety Valve is used regardless of application or design.
I note you already started your query in thread794-474088 You're effectively posting an extension to your earlier post.
Thank you for your reply, but in my previous thread I was speaking about rectangular flange.
Now I want to do an elliptical flange.
I don't have any sketch.
