  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Add a non-attribute item to Assembly Navigator
kchoj
Industrial
Dec 20, 2013
13
Is it possible to add non-attribute item (Component member in part) to Assembly Navigator?
NX 11
What do you mean exactly with "Component member in part" ? Maybe an attribute can be created for it.
The columns in the ANT are only displaying attributes.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
When you do Info > Object on a component one of the lines in the window is "Component member in part", showing the directory where that component is coming from.
I know there is a command (information > assemblies > list components) that will show me that.
Can I make that information show up in the assembly navigator?
