Add command
TheMark
Automotive
Jan 3, 2007
3
I have extruded a flat plane into the side of a cylinder in Ideas and I would like to join the two together. In addition I would like the portion of the flat plane that is inside the cylinder deleted so that the edge of the plane becomes the circumference of the cylinder. How do I do this? I have played round with the extrude commands and I can’t get this to work.
What version of I-deas? If 11 or higher, there should be a pulldown to Join the Extrusion with selectable geometry.
This is called a Boolean operation and most softwares call it a Unite or Union rather than Join. There are 2 other Booleans, Subtract and Intersect. All 3 are quite common when creating Revolutions and Extrusions as well as other Swept bodies.
Tim Flater
Senior Designer
Enkei America, Inc.
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
