Add material
Santa123
PL
I am creating a macro, which add material to part, read mass and put it to lblMassValue. Button2 add material to Body but weight is not updated, it stays the same as it was without material.
Code:
Public Class Form1
    Public MyActiveDocument As Document
    Public MyProduct As Product
    Public MyParamMass As Double
    Public MyPart As Part
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        MyActiveDocument = GetCATIA.ActiveDocument
        MyProduct = MyActiveDocument.product
        GetCATIA()
    End Sub
    Public Function GetCATIA() As INFITF.Application
        Try
            GetCATIA = GetObject(, "CATIA.Application")
            lblMasaValue.Text = MyParamMass
        Catch NoCATIARunning As Exception
            GetCATIA = CreateObject("CATIA.Application")
        End Try
    End Function
    Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
        Dim CATMatManager As MaterialManager
        Dim MaterialDocPath As String
        Dim MaterialName, MaterialFamilyName As String
        Dim MaterialDocument As Document
        Dim MyMaterial As Material
        Dim MyBody As Body
        Dim LinkMode
        Dim anlysisMaterial As MaterialManager
        MyParamMass = FormatNumber(MyProduct.Analyze.Mass, 2)
        MyPart = GetCATIA.ActiveDocument.Part
        '*************Identify Material ******************
            MaterialName = "Oak"
            MaterialFamilyName = "Wood"
        ' *************Identify the Material Doc Path: *******************
        MaterialDocPath = "C:\Program Files\Dassault Systemes\B27\win_b64\startup\materials\Catalog.CATMaterial" '*
        '**************Modified From the AutomationV5.chm File:
        MaterialDocument = GetCATIA.Documents.Read(MaterialDocPath)
        MyMaterial = MaterialDocument.Families.Item(MaterialFamilyName).Materials.Item(MaterialName)
        CATMatManager = MyPart.GetItem("CATMatManagerVBExt")
        MyBody = MyPart.MainBody
        ' Apply the material on the Product (as a link)
        LinkMode = 1
        CATMatManager.ApplyMaterialOnBody(MyBody, MyMaterial, LinkMode)
        ' Retrieve the material applied on the Product
        MyPart.Update()
        lblMassValue.Update()
        lblMassValue.Text = MyParamMass
    End Sub
End Class
Hi LucasC
Thank's for response, finaly I found mistake in my code. I only added Call and it works.
Code:
Public Class Form1
        GetCATIA()
    End Sub
        Try
        End Try
    End Function
        Dim MyBody As Body
        Dim LinkMode
        LinkMode = 1
        MyPart.Update()
Call ShowMass()
    End Sub
    Sub ShowMass()
    End Sub
End Class
