NaWin55
- Mar 21, 2020
- 98
Hi Everyone
Is there any way to add relations to dimensions of a sketch quickly using automation technique
What i want is select a dimension and add relation to it with other dimension so that if one dimensions parameter is changed the part should get updated according to different input of parameters
this can be done using KBE but any way in VBA automation
