Ronak_Patel
- Jul 26, 2021
- 43
Hello ,
I`m working on revamp project in which My project team has asked me to check mechanical adequacy of Pressure vessels. Equipments were built on ASME 1993 code and are in operation since 1995.
(a) Im confused about the use of code ,whether latest ASME shall be used to check shell thickness or ASME 1993 ?
(b) since equipment are in use for some 25 years now , there must have been some corrosion . Client has not provided any health check up report so i do not know current shell thickness of equipment . what shall be sensible assumption ? corroded thickness or uncorroded thickness of shell . Is there any ASME Procedure or requirement ?
thank you!!
thank you!!
