REFERENCED EQUIPMENT IS USED BY CONSTRUCTION CREWS WORKING OVER WATER. REFERENCED EQUIPMENT ARE MOUNTED ON BARGES, SHOULD THE CREW INSIDE OF MANBASKET BE REQUIRED TO WEAR BODY HARNESSES? BEFORE QUOTING OSHA REGULATION BE AWARE THAT SUCH EQUIPEMENT CAN FALL OVERBOARD DRAGGING EVERYONE WITHIN THE MANBASKET UNDERWATER.
