Respawn
- Sep 28, 2020
- 64
I was looking over some plans for learning purposes and I saw a RFI that said "3/4" aggregate size is acceptable for beams, columns, slab except for use in high rebar and post-tension congested areas like column to post-tensioned beam connection". It then pointed to use 3/8". Why would a 3/8" aggregate size be preferable in said regions? I know it affects workability.
