Jul 29, 2019 #1 mtnz Aerospace Dec 4, 2018 21 0 0 US Hi Guys! I know 1144 is an oil quench material. I was just curious what happens if we air cool 1144? Would it be still hardened ? Thanks!
Jul 29, 2019 #2 EdStainless Materials May 20, 2004 15,893 0 36 US Thin parts? Forced air? Might work. = = = = = = = = = = = = = = = = = = = = P.E. Metallurgy, Plymouth Tube Upvote 0 Downvote
Jul 29, 2019 Thread starter #3 mtnz Aerospace Dec 4, 2018 21 0 0 US 1.5" thick, 14" long pin ? Upvote 0 Downvote
Jul 29, 2019 #4 EdStainless Materials May 20, 2004 15,893 0 36 US No chance at 1.5" diameter in air. Will it through harden even with an oil quench? = = = = = = = = = = = = = = = = = = = = P.E. Metallurgy, Plymouth Tube Upvote 0 Downvote
Jul 29, 2019 Thread starter #5 mtnz Aerospace Dec 4, 2018 21 0 0 US You mean it won't get hardened at all? Upvote 0 Downvote
Jul 29, 2019 #6 EdStainless Materials May 20, 2004 15,893 0 36 US The outer surface will, but the properties through it will be lower, and maybe rather bad. If this pin is going to be loaded you might want to re-think your grade. = = = = = = = = = = = = = = = = = = = = P.E. Metallurgy, Plymouth Tube Upvote 0 Downvote
Jul 29, 2019 Thread starter #7 mtnz Aerospace Dec 4, 2018 21 0 0 US I don't need to thru harden the pin. I need to case harden it, so I believe it will work then ? Upvote 0 Downvote
Aug 15, 2019 #8 weldstan Materials Jun 24, 2011 2,730 0 36 US Probably not; depends on the surface hardness and depth of hardness required. Upvote 0 Downvote
Aug 15, 2019 #9 weldstan Materials Jun 24, 2011 2,730 0 36 US I assume you still wish to air cool. Upvote 0 Downvote
Aug 16, 2019 #10 Tmoose Mechanical Apr 12, 2003 5,626 0 0 US Are you buying 1144, or "sress proof" ? Upvote 0 Downvote
Aug 19, 2019 #11 Guest 1144 should respond very much like 1045, a very common material for which there is an abundance of data. "Everyone is entitled to their own opinions, but they are not entitled to their own facts." Upvote 0 Downvote
Aug 20, 2019 #12 dbooker630 Materials Apr 16, 2004 525 0 0 US You can expect hardness around 269 HBW (28 HRC) after air cool in this section size. Upvote 0 Downvote
