Airfoils
cft21
New member
I have a question about the nose down pitching moment. When talking about cambered vs. a symmetrical airfoil, do they both produce a nose down pitching moment or just the cambered airfoil?
airfoils, by convention, have their lift vector at the 1/4 chord point, which is close the the CofP of early NACA profiles.
moment is then created by having the CofP away from the 1/4 chord position, so any airfoil "can" have aero. moment.
Any airfoil producing lift produces circulation, which produces a moment. A flat plate at an angle of attack produces a moment.
Good point btrueblood. It's common to put a symmetric airfoil on a trimmable horizontal stabilizer.
Trimming the stab (ie changing the AOA) will produce a pitching moment.
What if both airfoils are at their respective zero angle of attack?
a symmetric airfoil at zero AoA has no lift, no moment (and i guess, theoretically, no drag ... but that looks odd !?)
a cambered airfoil would produce lift at zero incidence and quite likely moment as well.
No drag? Tell us about your new theory, then go read up on aerodynamic drag.
Timelord
yuk yuk ...
i was mentally following on from no lift, no moment (ie no anything). in any case, with no lift (no Cl) so no induced drag, but i guess you are left with a little profile drag.
What if there is a little bit of turbulence in the flow. I would expect the instantaneous pressure differences btw top and bottom to produce some kind of aerodynamic lift/moment.
At what main frequency would you expect the airfoil to vibrate under these conditions?
Fe
that would depend on a host (sory, make that a Host) of factors ... the structure of the wing, the frequency and magnitude of the forcing load, ...
i was answering the OP from a steady-state viewpoint. maybe also a 2D viewpoint
Not sure quite how good it is as it's description of fundamentally why an aerofoil generates lift isn't the one my prof taught at uni. However, it has a section on pitching moment.
For some reason I was thinkin the wing usually generated a nose up moment, I clearly am forgetting all I learnt in aero and need to re-read my old mechanics of flight book.
KENAT,
Have you reminded yourself of faq731-376 recently, or taken a look at posting policies:
For a symetrical infinite airfoil:
moment coefficent is essentially zero for any angle of attack.
Chambered produces negative moment coefficient. Essentially constant for any angle of attack.
Now, for a total system such as an aircraft, the center of lift relative to the center of gravity does produce a moment. This is often nose down which is balanced by the horizontal stabilizer.
I suggest looking up a typical NACA airfoil lift curve.
