Deener
- Aug 30, 2018
- 49
Hey guys,
I'm checking the strength of a fillet weld used to connect an end plate to HSS in a pin connection (HSS is diagonal cross bracing for a frame). I have uploaded a snapshot of the connection.
To increase weld length and to help with shear lag, we have added a stiffener around the perimeter of the HSS. All plates will be fillet welded on both sides. Summing the total length of weld, we exceed the requirement of staying below 100*weld size. This would mean we have to apply a reduction factor (referred to as ß by the AISC)to the effective weld length. In fact, we even exceed the next requirement of staying below 300*weld size so we are forced to use a weld length of 180*weld size. I don't believe this should be applied in our case because this is not really the end loaded fillet weld that the AISC mentions (i.e. weld direction is not purely parallel to the load). I'm wondering if others have an opinion on this? I'm also looking at reducing the end plate thickness. Seems a little odd that the plate is 1.5" thick and the HSS wall is only 1/2" thick. Perhaps this is driven by bearing of the bolts.
Thanks in advance for your comments.
