Al to Steel and Al to Concrete Connections Beachfront
bookowski
I've got a few situations/connections here that are outside of my knowledge base.
This is a beachfront resort, these details will be repeated on around 15 of the same structures. I've designed the concrete buildings for this project and various canopies and accessory structures are theoretically designed by others. However, I've been asked to opine on the proposed details beyond only the loads imposed on my structure. There are a lot of mixed materials and the drawings do not indicate any measures to mitigate corrosion potential. I'm not sure how much I'll be able to make them change these but in my review I'd like to at least note the problems and possible solutions for them to consider to push the risk back to them. The concrete buildings will get stucco as their finish.
Condition 1: A small trellis like canopy mounted to the face of the concrete building. This is about a 3 ft cantilever of open repeating fins, imagine a ladder turned sideways and bolted to the face of a building. Currently proposed detail shows a steel perimeter frame (think ladder side rail) and aluminum infill members (the ladder rungs). The Al and steel are shown directly connected. The overall frame is shown as being mounted with post installed anchors to the concrete. Forget about loading/demands here, just corrosion. They've already suggested that they could change this all to aluminum. If this is all aluminum would it be sufficient to apply a coating to the face of the concrete to separate the Al from the concrete? Stainless anchors for the post installed with a separation coating or washer? All of this is more or less exposed.
Condition 2: A much larger exterior canopy/pergola type structure. This one has long spans and some big cantilevers. Again, they are proposing steel for the main spans and cants and infill being done in Al. This one also interfaces at one side with concrete. This one has an extra corrosion twist. The long spans are shown as wf steel which then gets clad in bent plate to make it a sharp square. To accomplish this they show a lot of small "cold formed framing as required", presumably shot into the steel to hold it in place and likely touching some Al here and there even if inadvertently. It feels like that cf steel would not last long to me. Similar questions to #1 - what is a robust separation detail for these various interfaces, and what happens to cf steel in an exposure like this?
Being beachfront and fully exposed is it sufficient in general to separate the Al and steel by a coating alone? This is an aggressive environment, is there a more robust measure that should be used for separation? Note that in some cases the connections do hold cantilevers or other members with non negligible demands. As usual this is an "this is what we've always done" situation.
Based on some recent research I've done, I came to the following conclusions concerning contact of dissimilar materials. I think this is basically what you're already saying but I'll include anyway in case it's of use. :
Aluminum and:
Concrete - NOT OK
Stainless Steel - NOT OK
Galv. Steel - OK
Plain Steel - OK
PT Wood - NOT OK
Stainless Steel and:
Concrete - OK
Galv. Steel - NOT OK
Plain Steel - NOT OK
PT Wood - OK
Galv. Steel and:
Concrete - OK
Plain Steel - OK
PT Wood - OK
I'm not sure if providing a coating between dissimilar material is adequate.
Not only would you need coating but plastic washers also so that the fasteners don't electrically connect the two metals.
I could quibble with some of those cases but in a coastal application you have to be extra careful.
Materials that out in the open will do better than ones under an overhang.
Being washed by rain is better than the salts just accumulating.
Thanks.
- For the condition 1 - the aluminum "ladder" bolted directly to concrete over a long length (about 50ft continuous) I don't see using washers, like standoffs, making sense. How about a wide band of a peel and stick membrane that gets squished in there when the ladder is anchored
- Is there a special material/washer that protects the body of the bolt from the sides of the hole?
- Galv and Al aren't terrible, but I was thinking that I'd still want a separation for when/if the galv is rubbed away or consumed. These are ~15M residences so any kind of corrosion is going to be a problem.
Considering that, I would tell them that everything has to be stainless steel. End of discussion.
I'm sure that some kind of membrane might work (until it eventually deteriorates), but it's also easy for a contractor to forget to install it or install it poorly.
Heh - I thought this thread was about artificial intelligence!
You have to isolate aluminum from the concrete... the high pH of concrete is not friendly to Al.
Yes, that's why I was asking if there's a good/standard detail to achieve this in the described configuration.
