BridgeSmith
- May 22, 2009
- 5,010
We've had the issue come up a few times now where our seismic isolators are mis-aligned because the steel girders weren't at the base-line temperature when the girders were set and attached to the isolators. So, then they're deformed when they're not supposed to be, and have the potential to be laterally deformed more than allowed at the extremes of the temperature range.
I'm curious if anyone has seen a solution/mitigation strategy for this issue?
