Alignment 1
ianstifle
Marine/Ocean
Jun 30, 2004
14
I have two shackles on opposite sides of an assembly, and need them to align with each other so that I can then connect them. Is there any way to do this other than calculating the angles and using the angle relation?
Lot's of ways. The easiest I can think of off hand (but this depends on what version of SE you're running) is to create a couple sketch lines at the angles you want the shackles at and then mate the shackles to the sketch lines. To change the angle, edit the sketch.
--Scott
For some pleasure reading, try FAQ731-376
