Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hi AoA , the criteria is , the deflection between support shall be less than 1/2 in. (13 mm) and the bearing stress does not exceed 85 psi (the support must be wide enough ).AoA (Mechanical)(OP) said:Hi, what would be the allowable deflection for FRP Pipe supported on pipe bridge above ground.
Would appreciate your help in this.
