Gopher13
- Jun 21, 2016
- 94
I have this exact phrase in both my general structural notes and specification (both in the concrete and earthwork sections), "Do not place concrete on frozen ground nor allow ground beneath foundations to freeze." It is also written in bold and underlined. The attached photo is 10 days or so after they poured. The strip footing on the near side of the photo was just covered with poly with not additional sheltering or heating. As a result, the ground around it and under it froze. What is my move? Maybe one option would be to measure the elevation of the footing with frozen ground in relation to the footing with the unfrozen to see if it has moved at all. Then have them thaw the ground below and around the frozen footing and have them take similar elevation measurements and compare the two?
