UK is for Univ of Kentucky...and to add to my misery, I'm a bigger football fan than basketball.
Are you saying if the cracks are longer on the inside, DTF could be the problem... and
Are you saying if we have DTF, we should insulate the lugs??? Usually you don't see lugs insulated, do you???... please advise.
Where can I find more info of DTF???
I was going to feather out the filet welds after fabrication to remove stress concentrations at the toe. I was also going to caution the fabricator about undercutting in this area.
Although DTF could play a roll, the biggest stress of the vessel is the 30# steam. We steam sparging and the vessel makes a lot of noise. Attached piping, etc. shakes, so I know these high frequency loads are being transferred to the vessel...and it's anchor points (i.e. We put the vessel on springs 2 years ago, but the spings broke.) I looking for ideas if there's anything thing I can do about that, besides make the shell/lugs thicker.
Thanks for your input...
