Alternate terminology for a swivel flange?
Arron_
18
What would you call a swivel flange outside of the US that is more of a ducting flange with no gramophone or raised face or anything, just a laser cut flange.
Drawing?
No drawing, it's just a 10mm thick ring with bolt holes in it
Plate Flange, Yep that jogged my memory. Thankyou
/edt; a lap joint flange? Man, a drawing would make this guessing 10x easier.
Loose ring flange?
Solved guys, thanks. It's a Plate flange.
Well if all you meant was the ring bit, I would call that the backing ring. If someone called out a " plate flange" I wouldn't have known what it was and I'm outside of the US.
Interesting how the same thing can have so many different names....
Plate flange rings a bell to me; a blind flange!
Back in the day (UK)the description I used was "Loose Captive Flange". It is a Lap Joint Flange, but few people understood what it meant.
Per ISO, only the term Safety Valve is used regardless of application or design.
