jochav52802
- Nov 28, 2018
- 81
Good Afternoon,
A few quick questions regarding reinforced concrete design per ACI 318-14:
1) Is it a requirement to alternate the dowel legs that enter a slab from a supported wall, or can the dowel legs be on the same side? If not, why is this done in practice? I have a slab that requires a 90-degree hook, but I don't have enough room in the slab to have the hook face outwards.
2) For a 90-degree dowel hook, when more reinforcement has been provided than is required, is it possible to reduce both the dowel hook longitudinal and lateral hook length proportionately to the ratio of required steel-to-provided steel? I don't see this spelled out in the code.
Many thanks for your help; I can't locate an answer on this within ACI 318-14.
Best regards,
jochav52802
Best regards,
jochav52802
