Amada lc2415 laser panel won’t power on
Dablaingc
Industrial
I have an Amada lc2415 Aii and when I start the machine only the Fanuc panel powers up but not the laser panel below the controller.
Sometimes the small segment display powers up for a brief moment and then goes off.
I’ve checked breakers and everything else I could think of but haven’t had any luck.
What board do I need to look into replacing or checking
I’m also getting a air low alarm for the incoming compressed air but I’ve varied I have correct pressure and can’t get it to clear
Behind the machine, Down by the CNC breaker, open the two panels. Inside the one on the right are yellow boxes with a dark gray front. On the bottom of one of those boxes are little green fuses. Check the resistance on those and see if they are blown.
This requires you to check one by one, from the laser control board to the sensor. You need a professional inspection, You can contact us YiHai Laser; we have been engaged in the laser industry
