Anyone familiar with the standard material used by ABC in the mid 90s for Metal Building System main frames? Looking at some options for adding insulated panels inside, and we need to hang them from the overhead. When I assume A36, I get results I expect - the existing construction is coming in at 1.00 and 1.01 utilization ratios at critical points based on DG 25 using current code. I know they're using Gr. 55 plate nowadays for built up, tapered members, and I know the usage goes back a ways, but I'm not sure how prevalent the usage was into the 90s. Was it a standard or an "as needed" upgrade?
I have a call in to ABC to see if I can talk to somebody about it (maybe even pull the original drawings if somebody forgot to clean out a drawer), but figured I'd ask. I know a handful of the members here are active in the MBS industry.
Thanks.
Thanks.
