D.Jaya
- Sep 11, 2017
- 29
Dear Structural Engineers
It is required to design a RCC structure as the entrance gate for a land development scheme
I want to start the analysis using a software package and want to model the structure
It is required to clarify the following matters
1) If I model the structure as mentioned and include the loadings,end conditions etc and run the analysis and as a part of the design provide reinforcement according to the resulting Bending moments and Forces is it OK ?Or otherwise do I need to carryout an arch nalysis(by considering this structure as a fixed arch?
2) Since the loading to the structure is small (only the self weight of concrete applies) and also in order to reduce the thrust acting on the abutment/supporting columns if I limit the thickness of the vertical downward projections(of the arch) and the horizontal portion as 3”(75mm) is it ok ?
3) If I limit the thickness to 3” (75 mm), is it possible to use single layer of reinforcement?
