RaptorEIT
- Feb 7, 2019
- 34
Have an existing X-Shape lifting device that I have been asked to determine a rated capacity. The device appears to be of the type where someone in a shop through some shapes together and used it to lift something in the past without ever being engineered. I say that because of how the device was fabricated. The box shape is made from welding two 3x3x3/8 angles together. I have attached a picture of the device as well as a FBD sketch below that I have made in preparation for the analysis.
My primary concern when I first saw the device was the torsion that the side members of the X would exert on the longer, single member of the X. But, it looks like from a global standpoint that the torsion forces cancel each other out assuming balanced loading. The torsion can be resolved into a force couple on the single member of the X. The bad part is that the force couple creates a large compressive and tensile load on the local section coming from each side.
I'm thinking the local effects are going to be the limiting factor (local buckling of bottom angle leg, local bending of top and bottom vertical angle legs, and local bending of top angle leg). I'm using ROARK 7th ed. Table 11.4 Case 1c for the local leg bending, and ROARK Table 15.2 Case 1a for the local buckling. For the local bending of the vertical elements, I am going assume the moment is the Torque moment and then calculate the plate section to compute max stress.
I'll check the overall member strengths and pad-eye strength too, but those items are relatively straightforward. The welds framing the two angles together are all continuous so I'm not worried about them.
Am I missing anything, is this approach correct? I want to make sure I evaluate the cross section a "D" correctly.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1560529233/tips/FBD_cbgkpf.pdf[/url]
Thank you
Thank you
