Does anyone know how Equation 8-7 used in TMS 402-16 is derived?
This mode of failure uses the area of the anchor bolt for crushing of the masonry. I thought crushing in this scenario would be dependent on the depth of embedment.
I'm seeking this out because I'd like to determine the shear capacity of an anchor through the face shell of hollow CMU (actually, through bolted to the opposite face of wall). It's in the field of the wall (not close to any wall edges). I figured that pryout and breakout wont be applicable. Wanted to consider the crushing area as a function of the anchor's diameter and the thickness of the face shell.
