kaffy
- Jun 2, 2020
- 188
Good Morning fellow engineers,
This is the first time I am working with Kwik Bolts(Anchor Bolts). I checked the allowable shear and allowable normal of the kwik bolt(Included edge and bolt spacing). What other Criteria do I need to check?
I was looking at one example where concrete and pull out was being checked as well. Also the data on Kwik bolts showing tha allowable shear and normal, is it for bolt failure/bolt coming out of concrete or concrete failure?
Thank You
Thank You
