I need to check allowable tensile/compression load for the Ø2.5" anchor rod with a pin eye made of forged steel (ASTM A235 class C) as shown in the attached file.
The pin eye has been cut off of the original forged steel anchor and welded to 350W round bar shaft. It was tapped to accommodate Ø3/4 threaded rod which joins both parts together and acts as a backing for a groove weld all around.
The ASTM A235 has been superseded by A668 which indicates the equivalent steel grade to be A668 class B.
I`m trying to find out if this steel forging is weldable and can be welded to 350W steel.
The other question I have is whether Ø3/4 threaded rod tensile strength can be combine together with the groove weld to determine the overall capacity of this assembly.
I`m thinking that some of the strength from Ø3/4 threaded rod should be accounted for as it will provide additional resistance to the welded part of the joint.
Please let me know your thoughts.
