Givemeamoment
I am anchoring this 40' long x 8' tall metal artwall on a wood framed residential home. The metal artwall is made of 1"×1"x1/4" tubing and perforated metal with mounting plates at odd intervals, which makes it challenging to tie in at every stud. It also cantilevers 6 inches from the wall to allow room for different lighting. The wall is 7/8" stucco over 5/8" plywood then woods studs. I don't have much experience mounting anything over stucco but I don't think it makes sense anchoring to it. I'm not so sure that anchoring through to the plywood would suffice either, So my questions are:
1) Are there any type of toggle bolts (although typically used for drywall) that could be used in a similar way for plywood?
2) If anchoring to a stud is an option, are Z values for lag bolts and wood screws calculated the same way per NDS Table 12F?
