Angle Line Command
MechEngLR
1
I am using Draftsight and am having a few issues with the angle line command. It's been working correctly but something has changed and I can't figure out the solution. I was just wondering if anyone knows what the fix is.
If I want to draw a line 45 degrees to the x axis 100 mm long, I have been using the command @100<45 and it's been working correctly. Recently when I put in the same command the line is being drawn with the 100 mm in the x axis direction so the required line length is longer than required, this also makes the angle incorrect.
I was just wondering if anyone else has experienced the same problem? Any thoughts would be much appreciated.
