Angle on Swept Surfaces in NX 9
Hi Jashe,
I don't understand exactly your design, but have a look at the angular law
Didier Psaltopoulos
If this is a straight, linear sweep, - use the NX feature Extrude instead.
The Extrude has a "taper" option to angle the sides inwards or outwards using one or several angles.[ degrees]
The NX Swept has no "taper" option but a scaling option which can be used for the same purpose, but it does not allow to set the angle in degrees, instead it uses a "law".
Tomas
Thank you cowski. The draft command worked for me. Though I would like to understand more about the "laws" within that Swept command Toost. Also I was not able to find a "taper" option in the Extrude command. If you want to respond I will indulge but I was able to fix my issue.
The draft option in the extrude dialog is shown below. You may need to expand and/or show (click the gear icon in the top left and choose "more") that section of the dialog.
download.aspx
www.nxjournaling.com
