I am reading through the ANSI/HI 9.8 standard to be able to properly design a wastewater liftstation. I noticed that the standard uses D (bell outside diamter of the pump) to size the pump sump. While I know what D means when using dry wells, I am confused how to deterimine D when using submersibile pumps in wet wells.
