I'm currently working on oneline diagrams and I need to determine the current rating for the horizontal bus in motor control centers, switchgears, switchboards, etc. Which reference should I consider in order to write a voltage/current/short-circuit rating which is commercially available?
For example, for Motor Control Centers in ANSI world I was looking the NEMA ICS 18-2001 (R2007) which says in chapter "4.3 Continuous-Current Ratings of buses":
The horizontal common power bus shall have a continuous-current rating of 600, 800, 1000, 1200 amperes or higher as required by a particular application. Vertical bus extensions installed in a section shall have a minimum continuous-current rating of 300 amperes.
