Ansys ACT Mechanical - running .py file
L_K
267
How to run a python script file in ACT console?
Thanks. Do you know how to run an external py file from console. For example I have file "test.py" in the working folder which I would want to run?
The reason is that I would like to use for example notepad++ to develop a snippet (usually requires lots of testing and mistakes) and avoid copy pasting to console all the time.
Solution is the following:
exec(script), where script is a string of the contents of the file.
