ANSYS mechanical : How to read the dimensions which are defined as function of other dimensions in UGNX as parameters in ANSYS?
xinyu3liu
Automotive
Here is a example of this question:
I defined dimension A = 35 and I want dimension B to be equal to A +15, so I parameterized A and B in in UGNX.
I found that B is not identified as a parameter in ANSYS mechanical. Besides, in parameter set module I saw that when I changed several A e.g. 25, 27, 29... B is not changed, which is not desired.
Is there any solution for such condition? Any help will be highly appreciated. Thanks!
