1
- #1
wic45
- Jan 24, 2013
- 1
I have modeled my experimental bridge using beam and shell elements.
But when I run it in mechanical, have experienced an error as follows;
"An unexpected error ( SIG$SEGV ) has occurred"
What is the reason for that?
Also experienced with following warnings;
*** WARNING *** CP = 4.945 TIME= 17:40:43
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** WARNING *** CP = 5.164 TIME= 17:40:43
Material number 497 (used by element 13060 ) should normally have at
least one MP or one TB type command associated with it. Output of
energy by material may not be available.
In my model I have connect two line bodies by joints connections. I do not have any idea of the errors and warnings.
Can you please someone help me to solve this?
Thank you
Thank you
